Cd-r quality
Username: Xxraiderxx
1, Ga Us
Post Number: 12
if i burn a normal music cd will the new burned cd have the exact quality
Username: Turbodog
Post Number: 69
Yes, it's a bit-for-bit transfer.
Username: Turbodog
Post Number: 70
.... assuming you're talking about a home audio CD recorder. If you do it on a PC, then you may lose some quality if the PC is converting it to any compressed file format during the transfer.
Need to Register?
Forgot Password?
Enable HTML code in message
