High End Equalizers?
Username: Jim1961
Dublin, Texas USA
Post Number: 14
I would be interested in any recommendations. Transparency and low distortion and noise are the priorities, lots of bands isnt that neccesary. In fact, a five band would suite my needs. I also have no need for an analyzer or added tape loops.
High quality and simple here.
Username: Jan_b_vigne
Dallas, TX
Post Number: 11144
This is a job for ... Search Engine! Up, up and click.
Username: Kirthi
US
FilterBank is a high-end equalizer plug-in designed to emulate the sounds of ... McDSP's world-renowned emulations of vintage equalizers, compressors, ...
Username: Jim1961
Dublin, Texas USA
Post Number: 15
My first choice here would be a 2 channel, 2 band parametric eq. Anybody make a reasonably priced unit?
Username: Jim1961
Dublin, Texas USA
Post Number: 16
Found a 3 band parametric eq for $100. A PreSonusEQ3B. Anyone know about it?
http://presonus.com/EQ3B.html
Username: Jim1961
Dublin, Texas USA
Post Number: 17
also found a 4 band stereo unit, Behringer TUBE ULTRA-Q T1951.
Better or worse than the PreSonus?
Username: Jim1961
Dublin, Texas USA
Post Number: 18
I found a ART dual Tube Parametric EQ for $200
http://www.canadapromedia.com/sales/art/dualtubeeq.htm
Im going to buy it monday. Ill you all know what I think of it. Thanks for all you contributions!
Username: Nuck
Post Number: 8441
Jim, where was it 200$?
Username: Jim1961
Dublin, Texas USA
Post Number: 19
At a local guitar/keyboard shop in Austin, Texas. Its no longer longer there for I bought it. I must say, it meets all my expectations. Very clean and transparent!
Theirs another unit online for $350 (new) if someone else wants one.
Username: Jim1961
Dublin, Texas USA
Post Number: 20
Have to say, this solution turned out well. This EQ (ART Dual Tube) is much more transparent than the Hafler DH-110 pre amp was. The ART, coupled with a Adcom slc 505 passive was a significant upgrade.
Need to Register?
Forgot Password?
Enable HTML code in message
