BOSS BR-900 CD 8-track Help me please...
Username: Driesel
It is said in the manual that you should use a Delkin memory card... Is that just a sales trick, or anyone knows about other memory cards that are ok for using?
Roland has a chart listing tested brands of CF cards at:
http://www.roland.com/products/en/_support/faq.cfm?iCncd=34&FAQ=EN04-07966&dsp=1\
&ln=en&prd=BR864
1) Can A Zip Drive be used with the BR-900 ?
(internal or External)?
2)Will the BR-900 convert BR-8 files from the Zip Drive?
Username: Fleshtoast
how do i get into the rythem section 4 recording drums? every time i push the button, it takes me to vocal pitch correction
Username: Lisamonique
WI USA
Does the Boss BR-900cd have built-in speakers? I don't hear anything unless I plug in headphones- is that the only way to listen to play back?
Username: Ronny2010
Boss BR900 CD.
Can anyone help me.?. I am creating a rhythym track for my song in arrange mode in steps.For some reason when I get to the 50 step the machine defaults to erase and not to insert which means I can't progress beyond this point.Any ideas ?
Username: Pan_tile
Hi
I have bought a boss 900cd recorder can any one help me .Iwant to record my yamaha 2000 keybourd but do not know what connections i need.Any help would be great
Steve
Username: Rakearney
Is there a way to plug in 2 guitars plus the two mics to record?
Username: Lockyboy
I cant erase anything, I'm doing as the tutorial says but nothing erases...help
Need to Register?
Forgot Password?
Enable HTML code in message
