Thread: Yamaha DVD-C920 Five Disc DVD-Audio/Video/CD Changer Review |
Brian Mitchell |
| Posted on Tuesday, August 05, 2003 - 02:01 am: |
Yamaha DVD-C920 Five Disc DVD-Audio/Video/CD Changer Review Shopping for a DVD player is not as simple as it sounds. Sure you can find a $49 no-name player from your local mega store or online, but if you want the latest in convenience, quality and technology then be prepared to spend some extra dollars. Before you plunk down your hard earned cash, you need an HD-compatible or EDTV to get the most benefit out of the more expensive DVD players. If you are not sure, look on the back of your TV set for component video inputs (Y Pr Pb) which are usually three color-coded red, green, and blue RCA jacks. If you have this, you are golden. Read on... Video features to look for One of the most important features to look for is progressive scanning, which basically doubles the resolution of DVD video. To make things more confusing, all progressive scanning is not created equal. A company called Faroudja specializes in video scaling, and licenses their technology (DCDi) to DVD manufacturers. It corrects jagged edges and smoothes the picture, making it look much more life-like. Another important video feature to look for is 3-2 pulldown, which handles the process of converting film frames to the NTSC video for your TV. Music choices You thought that was all? There is more to know. All DVD players have a digital output for Dolby Digital and DTS surround sound. So the basics are already covered. But if you want the highest audio fidelity for music (not movies), you can get either SACD and/or DVD-Audio. Both DVD-Audio and SACD are superior sounding, incompatible formats, which require specially encoded music discs to work. Both technologies essentially sound the same for this discussion. The most expensive DVD players can play all formats, but you can usually save money by choosing one format or the other. Both DVD-Audio and SACD are new formats and nobody knows for sure which one will survive. For now, both are available, with limited music availability for each. Almost everything I am finally getting back the Yamaha DVD-C920 which has just about every feature you want in a DVD player I mentioned above, except for 3-2 pulldown and SACD processing. But at a list price of $399, you get exceptional video quality thanks to the progressive scan and Faroudja DCDi processing. Progressive or not Some people wonder if they need a progressive scan DVD player if their TV has a built-in line doubler, like most of the newer rear projection HD monitors have. The answer comes down to which line doubler is better -- the one in your TV or the one in your DVD player. In this case, the Yamaha DVD-C920 line doubler (progressive scanning) is much better than that in my Zenith 65-inch rear projection HDTV Monitor. Smooth edges A common example compares an American flag blowing in the wind. On regular DVD players the red and white stripes have many jagged edges while the flag undulates in the breeze. When progressive scanning with Fajoudja DCDi processing is applied, the stripes appear very smooth and realistic. This is just one example, but the video improvements make your DVDs appear much more film-like. One cable The audio connections from a DVD player can be somewhat complicated to the beginner. If you have a surround sound receiver then you can connect the digital output from the DVD player with one digital cable (optical or coaxial) from the DVD player to the receiver. This will work great for movies, but does not work for DVD-Audio or SACD. 6 channel, huh? To hear multi-channel DVD-Audio or SACD you need to use the 6 channel outputs from the DVD player to the 6 channel inputs of the receiver. This connection requires six RCA audio cables. Lastly, you must select the "6 CH input" option on the receiver to enable the DVD-Audio or SACD sound. What you have done is bypassed the internal processing of the receiver (which can't decode DVD-Audio/SACD) so your DVD-Audio/SACD player is now decoding the sound and sending the correct signals to the proper speaker. When you hear DVD-Audio or SACD for the first time, you will definitely hear a huge improvement in sound quality. Minimal surround options Now that you have completed the above you have to adjust the multi-channel surround speaker settings on your DVD-Audio player via the on-screen guide. The DVD-C920 has calibrations for speaker volume and surround delay in milliseconds, but there are no settings for bass management. DVD-Audio shines In addition to playing DVD-Audio and regular DVDs, the unit also plays MP3, VCD, CD-R and CD-RW formats. Audio performance across the board was great from the lower quality formats, while DVD-Audio discs sounded outstanding. Take Five Did I mention the DVD-C920 is also a five-disc changer? So you can put a few DVDs and/or a few CDs and play uninterrupted music or movies for hour after hour without leaving your chair. The DVD-C920 also allows you to change discs while a disc is playing. It took an average of 12 seconds to completely stop a disc and start playing another. Abnormalities Operating the DVD-C920 DVD player has some peculiarities. The remote is nothing exceptional; although it handles the most common tasks, expect there is no power (on/off) button on it. The on-screen menu graphical display, with tabs for each section, was a little cumbersome to get used to. Lastly, the progressive scan mode is off by default and must be manually enabled each time the unit is powered on. The bottom line Despite its nuances, there are two main reasons to buy the Yamaha DVD-C920. Because you want a five-disc DVD/CD changer and you want to play DVD-Audio discs. However, the stellar progressive scan video processing could be reason enough to justify its purchase. Pros Outstanding Video Fajoudja DCDi Progressive Scan DVD-Audio Quality Superb 5-disc Changer Convenience Cons Average Remote No 3-2 pulldown No Bass Management Usability quirks Yamaha DVD-C920 MSRP: $399 Yamaha DVD-C920 Features Yamaha DVD-C920 Specifications More DVD-C920 DVD Player Reviews Test system Yamaha RX-V740 Receiver Axiom Audio Epic 80 5.1/2.1 Speaker System Eighth Nerve Acoustic Room Treatments BetterCables.com Speaker and Interconnect Cables Zenith D65W25 65-inch Rear Projection HDTV Remember I am just one man with one opinion. If you own this product, or have a comment or question feel free to add your thoughts below. Brian Mitchell Founder & CEO eCoustics.com |
Relevant Product Info
Anonymous |
| Posted on Wednesday, August 06, 2003 - 04:03 pm: |
i guarantee that this thing has 3:2 pull down if it really has a Faroudja (note the spelling) DCDi chipset |
| Posted on Thursday, September 04, 2003 - 02:11 pm: |
Hey Brian, I DO have this unit (since last December) and positively LOVE it. Actually I have the 6480 which is the identical unit, but who can make sense of Yam's naming scheme. Anyway, nice review, but a few quick edits. 1. The unit does have Faroudja's DCDi chip which means that it WILL do 3:2 pull down. 2. There IS bass management. I bypass it in favor of the bass management that my HK receiver provides, but the Yam does have built in bass management. 3. There is an a "audio only" mode that will turn off all video functions for more pure music listening. 4. Does do MP3 but it's not the best implementation: no folders, no id3 readout, song ordering is arbitrary. Other than those two points, the review is dead on. The remote is NOT backlit and that's a drag sometimes (unless you have a universal). What you call "usability quirks" I totally agree with. There is no way from the front panel to skip from, say, disk 2 to disk 5 without skipping one disk at a time. You also mention the full 12 seconds from disk stop to disk play which can be long, it's the same at start-up. These nags notwithstanding, the Yam is a great box. It is VERY well constructed, dead quiet, and as Brian mentions the video AND DVD-A quality are fantastic. The 920 (and 6480) were both $599 when they came out last year, they are now $399 and haven't lost a step. Good review of a great piece of gear! -h1pst3r |
| Posted on Wednesday, November 26, 2003 - 06:21 pm: |
I wanted to purchase the Yamaha DVD-C920 but could not find one at a local retailer. They said it was replaced by the Yamaha DVD-C940 which was an upgrade to include both SACD and DVD-Audio. I did end up purchasing this unit and have not experienced any difficulty with is as a SACD, DVD-Audio, of CD player. However, when I attempted to hook up the component "p" output to my new Panasonic TH-42PA2O plasma TV, I detected "artifacts" actually scattered black pixelation. This pixelation disappears when I hook up the "i" component output, or the S-video output to the plasma. I then tried another progressive scan DVD player and did not observe this phenomenom. Hoping this was a problem with the Yamaha unit I purchased, I exchanged it for another but still have the same situation. Is it possible this DVD changer is not compatible with this particular TV? Or is there something else I should look into. I like the Yamaha because of all its features, but if the progressive scan produced artificats I'm not so sure this is the best unit for my home theater system. Any thoughts? |
New member Username: Noizboy
Post Number: 1 Registered: 01-2004
| Posted on Tuesday, January 06, 2004 - 02:41 pm: |
The C940 is listed as not having DVD-Audio.
Unregistered guest |
| Posted on Wednesday, February 18, 2004 - 12:19 am: |
Gail, Any followup on the trouble you had with the progressive outputs into the pany set? Do you happen to know if there will be a problem with the progressive outputs into other sets too? Thanks, Tom |
dforrest Unregistered guest |
| Posted on Wednesday, March 17, 2004 - 10:24 am: |
I am looking at this unit but I want DVD Audio. Everything I read says this has only SACD. Can anyone give me the truth? |
| Posted on Wednesday, March 31, 2004 - 11:19 am: |
The truth is the C920 does DVD-A only while the C940 does SACD only. |
