New member Username: TapPost Number: 1 Registered: Mar-07 | I have a JVC with DVD/VCR combo and I try to setup with all the connections but when I turn it on on the front display shows me that is Loading and stays like that for ever. I try to unplug and plug back on again and the same. I can't do anything with it. Please I need some help. Thanks. |
Gold Member Username: SamijubalPost Number: 3334 Registered: Jul-04 | Common on JVCs. Try contacting JVC, they know about the problem and may fix it for free. |
New member Username: JalloloPost Number: 1 Registered: Mar-07 | Hello everyone! I have a Sanyo DVW-7100A. It's a combo VCR-DVD. Does anyone knows how to unlock it? Thanks! e-mail: jallolo@yahoo.com.ar |
Bronze Member Username: DavidJOHOR BARU, JOHOR MALAYSIA Post Number: 21 Registered: Apr-04 | hello marano diaz pontelo en el culo wey aver si asi funsiona |
Bronze Member Username: Andy_manPost Number: 70 Registered: Apr-06 | >I have a JVC with DVD/VCR combo and I try to setup with all the connections but when I turn it on on the front display shows me that is Loading and stays like that for ever. I try to unplug and plug back on again and the same. I can't do anything with it. < Thats a problem that affected the first production/firmware batch of DRMV1 s and DRM10s manufactured before October 2004. Its a known issue and all dealers fixed their stock, but a lot of old unfixed stock was shifted via various unscrupios sources via ebay. Basially it`ll be out of warranty now regardless as it was discontinued over 2 years ago by JVC, but it needs a small update to the unit which involves a resisitor modification. Contact your local JVC service center if you really want to fix this. |
